Citizen Skyhawk Eco-Drive JR306059F Wrist Watch Logo
Posted on May 13, 2009
Second does not reset to 12
I have a citizen eco drive watch and the stopwatch hand does not set back to 12, how can i re-calibrate thanks
A
Anonymous
You should be able to solve this by pulling out the Crown(the one with which you set your normal clock), Pull it out in the 2nd stand.
Then by pushing the 'start/stop' button --> you change the minutes.
By pushing the 'lap/reset' button --> you change the seconds
It worked for me, took me a few minutes to figure it out, i hope this saves others the time of doing that :p
Change time
Welcome to Fixya,
If you need instruction on how you can set/ changed the time on your Citizen Eco-Drive Calibre 8700 Wrist Watch, you can try this link.
http://www.citizenwatch.com/COA/English/settings.asp
I would be more happy to assist you if I know your 4 digit Movement Caliber. You can found it at the back of your watch.
Hope this link will help you and can answered your question.
Thank you for using Fixya.
2helpful
How to set the time for citizen eco drive skyhawk.
Hi, This watch is Calibre C651, same as Model #JR3090-58M (Promaster Air Collection - Blue Angels Skyhawk). C651 is not available on Citizen website, but you can use Calibre C650 instructions. Download PDF manual and follow instructions on page 3. They are pretty detailed, so take your time, and you should be successful. If you don't have the manual, Try this link:
http://www.citizenwatches.com.au/instruction-manuals
Take the four-digit Calibre number (C651 or C650 in this case) from the back of the watch, enter it, and download a PDF of your watch setting-instructions/manual.
I hope this helps you. Thanks, Bill
1helpful
2answers
Citizen watch secondhand not moving
its a solar watch meaning you have to completely charge the watch under artificial light for 24 hours or full sun for 6 hours
3helpful
Adjusatet time and date for my eco-drive
You can get instructions from the Citizen web site.
Go to "citizen.com" and on the upper right there is a menu. Click on "technical support" and then on "setting instructions"
Fill in the information required from the back of your watch and then click on "get setting instructions"
4helpful
Chronograph hands reset to wrong places
go to the citizen web site (citizen.com) and select "technical support" and then "setting instructions".
Enter the number off the back of your watch snd the click on "get setting instructions"
The instructions include the steps you need to take to zero the hands.
My Citizen Eco-Drive second hand is broken
I think Its required Recharging capacitor
Put your watch under lamp light for 12 hours I hope that will solve the issue if not then capacitor need to be replace or watch need cleaning
hope this help
from
AmFix Jewelry & Watch Repair
203 N. LaSalle Street
Chicago, IL 60601
Ph: 312 641 7000
Email: [email protected]
Web: www.goamfix.com
8helpful
My Citizen Skyhawk Eco-Drive JR3000-51F Wrist Watch has stopped running. The analog hands have stopped at 12:00 and the left digital read out is flashing UTC and the right digital read out is flashing...
I had the same issue, and was able to reset it doing the following:
1. I let it recharge for at least a day in bright sunlight
2. I turned the selector to "CHR"
3. I pulled the crown all the way out.
4. I held both buttons down for 5 seconds (don't know if this was what did it.
5. I pushed the crown back in.
It did some funky hand movements stuff and then started off working.
My boss has a Citizen Eco Drive Skyhawk watch . . . how in the world do you set this thing? Every time I try, the second hands goes buck-nutty and spins around the dial a million times, then goes...
good morning ! to set the Eco Drive Skyhawk citizen watch,full the crown carefully wind it slowly until you reach the correct time after that push the crown back to normal possition, if the hand is turning back to the wrong time just press the button on the up side until the turn to the correct time,thank you ! god bless !...
1helpful
2answers
Citizen eco-drive problem.
Hi Try www.citizenwatch.com for your manual of instructions.
Try Leaving watch in direct strong sunlight or under bright light for at least 12 hours.
Top Citizen Watches Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Citizen Watch Expert? Answer questions, earn points and help others
