I purchased a used GE Dual Alarm auto clock set radio/alarm clock, and I can not figure out how to set the time/alarms! I don't consider myself an idiot, but am feeling like one. There is no "set" button, and I've tried pressing all the buttons (including the manual set at the back of the clock) to no avail. Has anyone got a manual out there they can share and/or a link to one online --- or anyone just own one of these things that they can help with? I have a feeling this thing was probably broken when I bought it.
What I have found with my alarm clock like this one is that you CANNOT be soft on it. When setting the time, hold down the F or R button extra hard. I know that seems odd, but it works!
Just figured this out myself after fiddling for a long time. If you want to set your alarm press the "select" button then the "ff" or "rev" to choose a time you want associated with your wake 1 or wake 2. Next go to the left side of the clock and press the "wake 1" and by pressing it you'll be able to choose the bell setting or the music setting. If you want no alarm just push firmly and hold until both symbols disappear. Do the same for "wake 2". I have yet to try this out but that appears to be how you set or remove alarms.
Hope this helps!
I have a solution for the GE Auto set clock and radio model number 7-4892A. The only way that I had found out just by accident is that you are suppose to hold down the manual clock set until you start to see the Year and then the Date. There you will be able to set it to the correct date or year.
Idea from
Guest
Sorry, the above link is bad. Here is the correct link. You will need Abobe Acrobat Reader, as it is a .pdf file. You will also have to use the magnifier feature to view the fine print.
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000045591.pdf
This manual should be similar...
http://www.amazon.com/74894-Clock-Radio-Green-Dual/dp/
How do I reset the time??
Thanks for trying, but that did not help my problem at all. My clock is Model #7-4892A. It does not have ANY time/date selector switch to set anything. It is printed on the front that it is "Auto Clock Set" however that doesn't seem to work. There is a button on the back to press for "Manual Clock Set" but I cannot figure out how to get it to work either. I appreciate your trying to help though!
i tried the suggestion in the manual link and it didnt work any suggestions
How to set time/alarm GE Auto Clock Set Radio Model 7-4892A problem...
I need the info as well...please and thanks!
