SOURCE: Audiovox Pursuit Pro keyfob reprogram
if thats the picture of the transmitter to program it you have to : turn the ignition to on position. press and release the programming switch 3 times... press and hold,for 3 seconds, the buttonof the transu wish to add until the parking lights flash. this would mean the transmitter has been learned. repeat step 3 for each transmitter... turn the ignition off to exit the program mode..
do not let 15 seconds pass between steps.
SOURCE: I have 1999 Toyota Highlander
Check the hood pin switch. It's located under the hood around the edge of the engine compartment. It's designed to make contact with the hood when the hood is closed. Also, check for a remote start shutdown toggle switch under the dash.
