Replaced Rotor Position Sensor...TWICE! Still getting LE code. There is a smaller white plastic sensor that goes on the stator assembly right next to the RPS. Does anyone know what that is called? I've looked everywhere and even called a few places and they see what I'm looking at on the diagram, but still don't know what it is. Is it possible this piece only comes with the Stator Assembly and I'm going to have to replace the entire thing?
SOURCE: LG washer wm1832c
I had the same error code along with the drum "freezing" up. The first unit that was delivered 2 years ago leaked water from the detergent compartment and they sent a second unit. I have only had this unit for 2 years and I am very disappointed in the LG product. LG was no help on the phone and I the only people that could service it were 45min away from were I live. I took the advice of a posting on this website that it could be a part called the sensor assembly (#6501KW2002A) and ordered it from an online electronics store (www.mcminone.com). To get to the sensor assembly, you first unplug and take off the back plate that has 4 small screws. Next, unscrew the big bolt in the middle and take off the hubcap looking part the bolt was securing. Next unclip the two sets of wires on the bottom of the circle you are looking at (the set of wires to the right are connected to the sensor assembly you want to replace). Next you will unscrew the 6 or so smaller bolts to take off the circular piece that the sensor assembly is snapped to. Take it off, unclip the old sensor assembly and clip on the new one – and reassemble. This worked perfectly for me and the part only cost $18 bucks plus shipping. When working, this product works well but I will not be purchasing any LG products in the future.
SOURCE: LG WM 1832CW
if your getting LE code on your LG washer check if your hot and cold water is hooked up right
SOURCE: le error code
LE is a locked rotor code, but usually means the sensor is not functioning. replace Hall sensor, if that doesn't fix it make surer the drum turns freely. the rotor never goes bad, and the stator almost never goes bad. replace board if sensor doesn't fix it.
