Posted on May 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Canon GP 200 is making a real loud clicking noise when it copies or faxes or prints, it even does the noise when the paper is loading. Can't find where the noise is coming from. Help Please...
Sunil Rathod
Level 2:
Sergeant:
  • Expert 199 Answers
  • Posted on May 13, 2009
Sunil Rathod
Expert
Level 2:
Sergeant:
Answers
199
Questions
Helped
93926
Points
627
They want some lubricant in back side chain & gear system
My Canon MG8120 all-in-one makes a loud noise when copying (not when printing). How do I fix it?
Dear
from the question I understand, the scanner move to right and during return it starts noise.
The problem with scanner assembly, It might be dust accumulated on gears, the scanner belt might have loose or the grips of the belt has worn out. Proper cleaning and lubricating the moving parts may overcome also if the belt worn out it has to be replaced.
In case of at home position it gives noise then the home position sensor may dirty/dusty, it has to be cleaned.
thanks.
Loud clicking noise on my hp printer 4500
hi, your priner complaint i 2 chance 1 is the carrage cable is damaged or 2 is printer mechanism complaint please verifing
1helpful
When I go to print or copy the machine makes a loud clicking noise and then says paper jam. Brother MFC - 8460 N
The loud clicking noise is either the toner cartridge or the paper feed. If the jam occurs in the drum and toner cartridge then I recommend changing the toner.
If the paper is not being fed at all then you need to have the paper feed kit replaced.
Thanks,
Pat
Canon lc 810 fax has noisy df
The noise is relevant to the modem which has been installed in the equipment.
I don't think you will be able to lower down this noise.
Canon imagerunner 1310 loud noise
Hello sir; I suggest reinstall drum unit again ,you will find out what's going on.
Recieving fax error
It could be a bad drum unit. If the drum doesnt turn smoothly it will make a clicking or grinding noise since it is gear driven. Take out the drum and turn the gear with your thumb. turm towards you. If difficult Thats it. It also could be a fuser gear. good luck Lawrence
1helpful
2answers
Canon gp 200
what the canon gp 225 ip address?
Outgoing fax makes loud clicking noise
2 different problems here. 1st is with document feed and 2 is with paper feed.
1st prob seems to be with the paper feed roller not meshing at the gear. Probably a broken piece on the lower document tray assembly. No real fix for this unless you can strip it out and haywire it.
2nd prob is probably a poorly meshing drum unit. Examine the gear teeth on both the drum and the machine. As you have replaced the drum already (presumably with a brand new one) You might possibly find a missing or badly worn tooth on the messhing gear in the machine.
25helpful
3answers
Its clicking
Check and make sure that if you have something plugged into the fax/phone ports that it is installed correctly.  I had this noise when I accidentally put the usb cable into one of the ports.
old marine
old marine
ZJ Limited
ZJ Limited
