Sigma 28-200 was not zooming or focusing. Looked like something was scratching the barrel. Upon further investigation, a leather-like cord seemed to be stuck inside. I tried pulling it out; now the lens zooms and focuses. Where did this cord come from? Was it original to the construction? Or did it somehow get wrapped around and stuck in there?
SOURCE: trouble focusing with sigma 70-300 DL macro super lens
It will not focus on anything closer than 5 feet.
(From Sigma lens literature) Capable of macro photography, this
lens has a 1:2 maximum close-up magnification at the 300 mm focal
length. It's the ideal high performance lens for portraits, sports
photography, nature photography, and other types of photography that
frequently use the telephoto range. It also has a switch for changeover
to macro photography at focal lengths between 200mm and 300mm with a
maximum close-up magnification from 1:2.9 to 1:2. The minimum focusing
distance is 1.5m / 59 in. at all zoom settings.
SOURCE: There is a tarnish to the eye of the lens Sigma Zoom 20-200mm
From your picture it is impossible to tell if the blemish is on the rear element or internal. The first thing I would do is clean the external lens surfaces then take some pictures. You may find that the blemish has no effect on picture quality. If that is the case, I would do nothing.
If it does affect your photographs, you will need to take it to a camera repair man. What ever you do, do not attempt to disassemble the lens yourself. You will not be able to get it back together and only add to the cost of repair. As far as cost, that is up to the camera repair man you choose. Without looking at the lens, he will not be able to give you an estimate. Check the cost of repair against the replacement value of the lens on E-bay and then make your decision.
SOURCE: My Sigma APO 70-200mm f/2.8 HSM lens functions
Am having the same problem. I fixed it once but can't remember how I did it. I think there are screws under the mounting ring -which has four screws itself. Then, I think under the green computer board, there are other screws that should be tightened... I will look at mine tomorrow and come back here to report.
