Replace the fuser
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: I want cd for instale KONCA MINOLTA PAGEPRO 1300W (driver)
Try this driver (choose the operation system)
http://crm01.konicaminolta.eu/openmind/technic/kmpsdwl.nsf/psearch?OpenForm&ch=PRI&dist=BPE&ui=en&dg=sw&prod=PagePro%201300W&dsg=&os=&lang=&ml=0&rid=41256849005CE173&sub=Printer%20Driver&pcat=B%2FW%20Printer&pcc=1
don't forget to vote!!!
SOURCE: Borderless printing
I don't think there is because it has to have some space to grip the paper through the drum and the fuser. Usually ink jets can do it but its tough to do on laser units.
SOURCE: lost connexion to windows server
Check if it's online in the Server, o a scan and print. The check the sharing status - is it shared ?
SOURCE: service call 05H
Flash ROM upgrade failure. Engine firmware upgrade failure. Attemp to re-upgrade. Check for proper firmware,
SOURCE: Konika Minolta Copier prints half dark pages
If it is only causing an image problem when you copy and not when you print, then there is something wrong with the optics under the glass. Check and see if you have any mirrors out of place or if the scanner looks crooked. If you have the machine set up to scan try and scan to SMB or email to see if it still has the problem. If everything looks correct under the glass and scans to SMB and email look bad like the copies, you may have a bad CCD assembly, or a bad board.
