Question about Whirlpool AWM8163 Front Load Washer
Whirlpool awo/d 53135 error f13 - Whirlpool AWM8163 Front Load Washer
6ya staff
SOURCE:
Anonymous
  • 27 Answers
SOURCE: whirlpool gb awo 3551 is not spinning of its
it cant work
Posted on Feb 21, 2010
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: My Whirlpool AWOE 8748 washing
The F30 error code will flash when the dispenser motor cannot be driven to its proper position.
* It could have a mechanical failure in the linkage between the dispenser motor and the top of the dispenser.
* Loose wire connection between the machine control board and the dispenser motor
* Failed dispenser motor
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 28, 2010
annapurna 70
SOURCE: Whirlpool AWO/D 7740 error code F23
error code f23
Posted on Oct 17, 2010
1tazza0
SOURCE: It is an awoe 8558. the spanner symbol is flahing
Hi, I have exactly the same problem. Did you ever get a solution to get the door open manually?
Posted on Nov 01, 2010
caroldon
  • 17130 Answers
SOURCE: whirlpool Awoe 1012 bearing
Check this link for spares and tips to replace: bearing replacement
Posted on Jul 06, 2012
Errore f02 modello awoe 8104
open the bottom tray door on front panel 3 screws on bottom front.
clean out the trap
May 10, 2014 | Whirlpool Washing Machines
Whirlpool awoe 8548
The f13 is a door lock error. You will need to replace the door lock mechanism, could also be the wiring or connections for the lock itself so check that first. Cheap part and easy to replace.
Jul 08, 2013 | Washing Machines
How to replace belt on Whirlpool AWO/R4205
Please find tips from the link below on how to replace belt.
click on Washing machine belt replacement
Nov 11, 2011 | Washing Machines
Cant reset my f13 fault and wen i power on it takes its take to lite front panel up
Hi again,
Whirlpool AWO 'F13' decodes as 'dispenser circuit failure'. If you have tried switching off and back on again and it is still there I suspect it means that you will have to call an engineer. Sorry ;-0(
Good luck,
John C
Mar 29, 2011 | Washing Machines
I have a F13 fault that wont reset on a AWOE9759. I do not know what a F13 fault is but i have tried what it says to do in the manual. Please help.
F13 Error = Dispenser circuit error
If the dispenser motor is not able to be driven to it's proper position.
Potential Causes
• Check mechanical linkage from dispenser motor to the top of the dispenser.
• Check Wire Harness connections to the dispenser motor and Central Control Unit (CCU)
• Check Dispenser Motor
Replace failed component.
Dec 26, 2010 | Whirlpool Washing Machines
My Whirlpool AWOE 8748 washing machine was showing error message F13. I swithced it off via the plug but the door will not open. Tried to switch it on again but no lights come on why?
Sep 04, 2010 | Whirlpool AWOE8748 Front Load Washer
My whirlpool washing machine keeps saying f13 whats wrong and how do i fix it
Hello, the F13 means "Dispenser Circuit Error", if the dispenser motor is not able to be driven to its proper position.
Check the following:
1. Check mechanical linkage from dispenser motor to the top of the dispenser.
2. Check wire harness connection to the dispenser motor and Central Control Unit and lastly
3. Check dispenser motor.
Thanks
Jun 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Apr 01, 2010 | Whirlpool Washing Machines
Fault codes f 13 Whirlpool Washing Machine AWO/D 5716
f13 is a Dispenser circuit error
If the dispenser motor is not able to be driven to it’s proper position.
Potential Causes
Jan 29, 2009 | Washing Machines
Whirlpool AWM8163 Front Load Washer Logo
125 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
