90% of the time if your washing machine will not work in the spin cycle it is because your lid switch is bad90% of the time if your washing machine will not work in the spin cycle it is because your lid switch is bad
You can't post conmments that contain an email address.
Hello. I'm a little confused at the description of the problem. You indicated it, "will not agitate during wash cycle or spin during the spin cycle." But later in your description you indicated, "It will however, drain and spin after wash cycle and during the rinse cycle." I'm not sure if you description was an error but it sounds like you will need to replace the coupling which is part number 285753A.
If your Maytag washing machine is agitating during the spin cycle, it could be due to a few different issues. Here are some possible causes:
Defective Transmission: The transmission in the washing machine is responsible for shifting the agitator and the drum between the spin and agitation cycles. If the transmission is defective, it may not be able to engage or disengage the agitator properly, causing it to spin during the spin cycle.
Worn Drive Belt: The drive belt connects the motor to the transmission and helps to control the speed and direction of the agitator and drum. If the belt is worn or damaged, it may not be able to properly control the agitator, causing it to spin during the spin cycle.
Malfunctioning Clutch: The clutch in the washing machine helps to regulate the spin and agitation cycles. If the clutch is not functioning properly, it may not be able to disengage the agitator during the spin cycle, causing it to spin along with the drum.
Faulty Timer: The timer controls the various cycles and functions of the washing machine, including the spin and agitation cycles. If the timer is faulty, it may not be able to properly sequence the cycles, causing the agitator to spin during the spin cycle.
It's best to have a professional technician inspect and diagnose the issue to determine the exact cause and the necessary repairs.
sounds like the timer is not advancing is certain cycles? timers have contact points that can burn and seize up sticking close and not allowing the next cycle to move
Hi, Ginger. We're sorry to hear about the difficulty with your washer. Below are links to our Use & Care guides, Parts Diagrams, Troubleshooting information and the Service are of our website. We hope this helps! http://bit.ly/112Lu7q
Thts right....the permanent press cycle my only spin at 600rpm because the clothes would be creased otherwise. Hence the PP cycle.
Some machines lock the PP cycle to low spin RPM. Some allow you to over ride this setting. Check your machine and have a play with the controls. Some PP clothing should even be drip dry to retain the premanent press in the garment. If you want PP then low spin is needed. fast spin will not be a PP cycle...
If you tried a different cycle and it worked this means that the timer is probably bad on the main cycle that you use. If the machine does not spin on all cycles, then please check out the LID SWITCH.
