door.
3 Push down on the green lever.
24x PaperJam, Check Tray
1 Gently open the ... Jam, Check MP Feeder
Gently pull the jam straight out of the multipurpose feeder.
202 PaperJam, Open Rear Door
1 Open the ... side to locate a
green lever.
Note: To clear the PaperJam error message, you must remove ... above Tray 1 when the duplex function is in use. To clear this type of jam, follow the instructions under the appropriate paperjam message.
Lever
4 Gently pull the jam toward you. 5 Insert the tray.
Note: Make sure... under the print media is locked down.
23x PaperJam, Remove Tray1, Pull Down ...
Maybe it's just me, but do you think that "Chevrolet 1983 K1500" is the correct place for this question?
it sounds to me that your paper level sensing switch is jammed or broken. Look for a micro switch that has an arm that lays on top of the paper stack. It may be bent or broken.
Good day, Check the table below about the problem of paper jams.
Displayand Meaning
[Paper Jam 0] - Paper has Jammed in the feeding area of the paper input tray. [Paper Jam 1] - Paper has jammed in the fuser area or in the manual feeder. [Paper Jam 2] - Paper has jammed in the paper exit area.
