AM GETTING A WATER FLOW INTERUPTED MESSAGE AND NOT PRODUCING A FULL CUP
SOURCE: Water just trickles thru getting less than 1/2 cup of coffee.
If you haven't descaled it yet, per instructions in the owners manual even if the warning isn't present, try that first. If that doesn't work, get a can of compressed air, and insert the nozzle of the can into the upper nozzle of the brewer, the one that pierces the top of the cup, and give it a blast of air. This will dislodge any crud that is preventing the water from coming thru.
SOURCE: Brewing is interupted and stops. It restarts
Water has been fed back into the main pump. It is at the bottom of the unit. You need to disassemble this and clean the pump out with cleaning alcohol. Once the pump is filled with the cleaning alcohol, shake it around until most of it is out of the pump and then let it dry overnight.
SOURCE: water flow is very little and quits before the cup
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
