I've tried this with cold, warm and hot water. The water will start filling for maybe 5 seconds and then stops. Think this is one of the 3 sensors on the top rear of the machine? I've replaced the main board to no avail. Thanks.
There are level sensors, I suspect one is defective, replace them.
If you have already replaced the main board then Its probably bad sensor. Have the sensors checked or have it replaced. I hope this helps. Have a good one.
Would you happen to have the factory listed name for this part (assy-sensor?) or part number? Thanks very much!
MAH2400a
Thanks.
