Samsung gas dryer error code EE the top line of first E is missing- won't operate beyond 5 seconds...
That is probably a TE (tE) error. That indicates a fault, usually a short, with the thermistor (temperature sensor). First check for a blockage in the dryer venting and lint filter. Next make sure that the vent hose is correctly connected to the exhaust of the dryer and the outlet. Check that the wires between the thermistor and the control board are undamaged.
If those are fine, the thermistor needs to be replaced.
I hope this helps. Please add a comment with the dryer model if you need help finding the parts list/diagram.
