Electric furnace runs for 8 minutes then starts to shut down but restarts for 5 seconds before completely shutting down. Repeat this cycle in 5 to 6 minutes after shut down. Recently had old thermostat replace with digital Honeywell RTH2510 model.
Check that the replaced thermostat is the same temp degree setting of the last one
Not sure what you are asking. Old thermostat was mercury switch type that was totally out of adjustment. However, we could find a comfortable temperature and the heater would cycle on and off within reasonable time frames. Current thermostat is set for 69F and shuts off at 72F. It is the shut off part that has me concerned. It does not shut down completely. It has a short restart of 5 seconds before it shuts down completely.
SOURCE: Heater blower motor cycles on and off (frequently). I have a class 2 LR95329 Honeywell Thermostat
I had the same problem with a Coleman. The problem is the blower relay. You can find this at http://mobilehomerepair.com
SOURCE: blower won't shut off on heat or cool cycles
Hi it souds like the afc is not working check the setings on it or clean the back of it /or replace
