One for ALL URC-7960 remote control.
Have you tried a code search method. If not, try it. Refer the user manual to remote control for details. If it too do not help you, there is no way other than to buy an other remote control, which has setup codes to your device it its code list.
If you wish to buy its original remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have setup code to your TV/device brand. You should first make sure about the number of digits in the codes to your device have. There are 3-digit, 4-digit, 5-digit and even 2-digit codes. You can get this detail by the code list attached to every universal remote control. The brand name of the remote control you select isn't a matter; but, its code list should have setup codes to your TV/device brand, otherwise you can't set it up with your device. Check this link and note which brand remote control have set-up codes to your device brand, and buy that brand remote control, according to availability. For more information http://electrohelponline.blogspot.com/ Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
SOURCE: URC-4041 Universal Remote
you may have problems getting any replacement remote to work here(or a code for any). The company is based out of China, contact details for them can be found at http://www.made-in-china.com/import-export/eJnQVugPRxZLprofile1/Chitech-International-Ltd.html.
You may be able to get a new replacement remote direct, Hope this helps. a "fixya" rating would be great for my time spent trying to get this info for you. Cheers :)
SOURCE: need tv code list for urc-4605
Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC4605
just right click and save as on the download links.
if this does not work you can try the search method,
you do
this by either holding down the device button eg: TV or if you have one
the "magic" button for three seconds, a light should then flash twice
to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(For low price replacement remotes visit www.sparky-uk.com)
SOURCE: Need the code for my DVD Player
Download the remote manual and list of codes from here:
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/one_for_all/urc4605-manual.zip&area=other
For a limited time only, you can also download it from here:
http://files.getdropbox.com/u/1322442/urc4605-manual.zip
