have the fault codes read first
just because there is no engine light does not mean that faults are not being recorded
items that can shut down the engine are
cam/crank position sensors
immobilizer system
bad terminals on the battery
bad battery
faulty alternator charge circuit
loose fuse in holder
faulty ECM unit
I'm having the same kinda problem but it's random or sometimes it duzent Finnish booting I know it's not over heating iv COMPLEATLY taken it apart and cleaned everything and applied new artic silver paste... and the ram is fine.. I have tested it in a nuther laptop.... It duz this on both battery and ac power.. Any clue what it could be?
You need to figure out which one you are losing. You are either losing fuel, or spark. When the engine quits, immediately open the hood, and check for spark. Let us know what you find. Good luck!
Could be several things, what are the symptoms. does it start right up after it shuts off? does it make any particular noise? rough idle before shuting down?
it could just be a partially stuck thermostat if your not losing any antifreeze. if you have white steam out the tailpipe then a headgasket or head problem is likely. dont keep driving this till you fix it because if its simple now its going to be a major fix later as you will damage the engine etc.
