SOURCE: My panasonic SC-HT830v DVD/VHS Home theater... Dvd drive will not open or close
try to apply a good brand contact cleaner(from radio shack or other electronic store near you)and press it many times.
SOURCE: I have the Panasonic SC-BT100
Cooling fan is probably dirty or not running. Check the fan by removing it with the two screws on the back and make certain that it's plugged in and the short, black wire (that appears to go to nothing) is "securing" the plug to the board.
SOURCE: How to connect pc to Panasonic SC-HT730 home theater system?
From what I can tell from your manual, you do not have auxiliary audio inputs on your system. You can, however, use the TV audio input for sound from your laptop. You will need to purchase an adapter cable that goes from male 1/8" stereo mini plug on one end (your computer jack) to a split (Y) male rca type jack (two connectors for R&L inputs on system. Then you'll need some length of 1/8" male to female miniplug extension cable. You can use the miniplug speaker jack on your laptop as an output.
Of course, if you're using the TV audio inputs, and don't want to unplug them to plug your laptop in, you'll need another pair of splitter cables for those rca jacks on your system so you can plug two different pairs of input devices into them, but I'd try to avoid this scenario if possible.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
SOURCE: iI have panasonic home theater SC-PTX7, it
Go to the website and enter the model # for Help.http://www2.panasonic.com/consumer-electronics/support/ Good Luck
SOURCE: blu ray connect to my sc-pt660
Why not leave the audio into the TV via HDMI from the Bluray and then optical audio out from TV to the home theater audio system? Same as the hook up for the cable box. The SC-
PT660 only has one optical audio connector so your solution may not be feasible assuming he's also got a cable box connected to the TV.
