Tablets & eReaders Logo
A
Anonymous Posted on Dec 17, 2013
My tablet is frozen - Tablets & eReaders
Teranice Price
Level 1:
New Friend:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Jan 05, 2015
Teranice Price
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
7
Questions
0
Helped
10023
Points
11
If you have it on the. Charger .unplug it till. It turns off even. At night. If it does turn off. Then plug. Back. In the charger
  • Teranice Price Jan 05, 2015
    If you have it on the. Charger unplug it. Till it turns off this. Could mean at night too if it does turn off plug back. The charger and it should say its charging
sandrasteven
Level 3:
Master:
  • Master 875 Answers
  • Posted on Dec 17, 2013
sandrasteven
Master
Level 3:
Master:
Answers
875
Questions
0
Helped
119232
Points
3345
What is the model? I suggest you can approach Unlocking4u.com and get unfreeze code for your Tablet device.they offer unfreeze code for Samsung models.
1helpful
When I click Google. Screen frozen. Why?
The operating system of the tablet is corrupted by viruses/damage, to solve this problem please reset the tablet to the original factory settings
Tablet wont turn on fully it freezes on the opening screen than just freezes there and wont turn on all the way what can i do to reset it
How to Fix a Frozen Samsung Galaxy Tablet [Solved] - Samsung ...
www.tomsguide.com/forum/id.../fix-frozen-samung-galaxy-tablet.html
2 days ago - 30 posts - ‎27 authors
I have a Samsung Galaxy Tablet that is completely frozen. ... If done correctly thescreen will turn black and automatically start the reboot process. ... Sure have, it won't turn off, swiping the front screen doesn't do anything. My Samsung tablet won't turn on! - Samsung - Android ...
Jan 17, 2016
My Samsung tablet will not turn on. - Samsung - Android ...
Dec 30, 2015
My RCA tablet won't turn on. What do I do? - Tablets ...
Dec 28, 2015
Help! My tablet won't turn on! what do I do?! - Asus ...
Apr 1, 2015
More results from www.tomsguide.com
2helpful
Tablet frozen will not return to home screen
Try to hold the power button down until the tablet reboots.
How to get back to settings on frozen samsung tablet
Tablet should have a "reset" button on top or side. Small hole. You need an object that would fit--it will take it back to factory specs. Make sure tablet is fully charged--or plugged in first. Worked for me.
2answers
Proscan tablet is frozen
Check for the reset pin hole on your tablet. Get a paper clip and push it 'gently' in the hole and hold it for thirty seconds. This resets the tablet.
Youdon't want to push hard as there is just a tiny button in there that can get dislodged.
2helpful
2answers
Ematic tablet screen is frozen
Well I'm trying to fix a ematic tablet because it frozen
1helpful
Kurio 7S Tablet is 3 days old; it is frozen on the App Menu Screen; cannot turn the device off; cannot do anything; it is frozen and has been for 30 minutes
Typically if you hold the power button down for about 20 seconds the tablet will restart. Some tablets will have a pin sized hole on the back that is a reset button.
My visual land tablet is frozen on the lock screen, it want slide to unlock the screen, what should I do
follow this steps and fix it. GOd bless you
Press the power button. Hold it for 20 seconds to force the unit to shut down.
  • 2 Turn the Tablet back on to determine if it is still frozen.
  • 3
    Remove the power adapter or USB cable from the Tablet. Turn it back off. Turn the Tablet over and remove the screw from the back of the device. Slide the battery panel off of the Tablet and pull the battery out of the unit.
  • 4
    Connect the Tablet to the power adapter and power it on. The freezing issue should be fixed and your Table should respond properly. Reinsert the battery and charge it to full before removing it from power.
  • Read more: http://www.ehow.com/how_8722116_troubleshoot-frozen-nook.html#ixzz2aUBnGy3w
    2helpful
    2answers
    128helpful
    3answers
    How to unfreeze my samsung galaxy 10.1 tablet
    Hold the power button and the volume up button for 10 to 20 seconds :)
    Top Tablets & eReaders Experts
    k24674
    ADMIN Andrew
    ADMIN Andrew
    Are you a Tablet and eReader Expert? Answer questions, earn points and help others
