try clearing your cache partition, you can get to the android recovery with your buttons.
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the red Motorola logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up).
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons.
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections.
6. Use the volume buttons to move up and down through selection in this menu.
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option.
9. Scroll down to select "Yes, delete all user data".
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
Hi, you need to perform a factory reset, follow these instructions:
For Android tablets you can do this wit factory reset from the Android System Recovery Menu. This will erase all your data.
To go into the Recovery menu, press and hold the Power On button and some other key (Volume Up, Volume Down, Home ). The combination is different for the different models.
When you are in the Android system recovery menu, use The Volume Up/Down keys for navigation and the Power button for confirmation.
Choose "wipe data / factory reset"
ANDROID Tablet Freezes at Android startup screen For Superpad VI - 10.1" Android Version 4.03, this worked for me!
1. Press & hold START button 2. When "VIMICRO" appears, Then Press & Hold the MENU button 3. The Android System Recovery <3e> Menu should appear 4. Scroll down using the Volume Key to "wipe data/factory reset" 5. Press HOME Button 6. Scroll down to "Yes - delete all user data" 7. Press the HOME Button At this point the system will do a recovery and hard start, and will be on "reboot system now 8.Press the HOME Button Your system should reboot normally, but you will need to enter all new data, as it has been wiped clean.
