One For All Kameleon URC-9964 Remote Control Logo
R
Rod Copland Posted on Dec 17, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bell expressvu need the code for bell expressvu 0775 does not work plus I tries all the ones in the manual.
Level 3:
Top Expert:
  • One For All Master 76,851 Answers
  • Posted on Dec 17, 2013
One For All Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14994617
Points
237762
Just try a code search method. Refer the remote control's manual for details. If it too doesn't help you, there is no other way than buying an other remote control, which have setup codes to your device, in its code list.
If you wish to buy its original remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have setup code to your TV/device brand. You should first make sure about the number of digits in the codes to your device have. There are 3-digit, 4-digit, 5-digit and even 2-digit codes. You can get this detail by the code list attached to every universal remote control. The brand name of the remote control you select isn't a matter; but, its code list should have setup codes to your TV/device brand, otherwise you can't set it up with your device. Check this link and note which brand remote control have set-up codes to your device brand, and buy that brand remote control, according to availability. For more information http://electrohelponline.blogspot.com/ Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
Need a code for hd satellite receiver 550hd from one for all remote
I couldn't find "AB IPBOX" in the satellite codes, but here is the complete list of satellite receivers in the URC 4081 manual. Hope one of them helps.
Setup Codes for Satellite Receivers:
AlphaStar 0772
Echostar 0775, 1005
Expressvu 0775
General Instrument 0627, 0361, 0869
HTS 0775
Hitachi 0819
Hughes Network 0749
JVC 0775
Jerrold 0627, 0361
Magnavox 0724, 0722
Memorex 0724
Next Level 0869
Panasonic 0701
Philips 0724, 0722
Primestar 0627, 0361
RCA 0566, 0143, 0392, 0855
Radio Shack 0869
Sony 0639
Star Choice 0869
Toshiba 0790
Uniden 0724, 0722
Zenith 0856
Need remote code for programming a bell expressvu receiver
Here for the Jensen remote just click below;
Here is link to the manual:
http://www.remotecodelist.com/remotes/jensen/JR300C.pdf
Here is some helpful information I found:
Without the code on JER-323:
1.Manually turn on the component you want the remote to control.
2. Press the device button, example:( TV) and the (power button) for 3 seconds until the (on/off button stays lit).
3. Once the (on/off) button is lit, press the (on/off) button until the unit (the TV or unit you are trying to control.) turns off.
4. When the code is located, press the (stop) button at the bottom to save the code.
Here are some codes I found for the Jensen 323:
GE VCR: 2000, 2013, 2021, 2022, 2053, 2087, 2089, 2091, 2115, 2120
Motorola Cable Box: 5000, 5003, 5046, 5047, 5052
Mitsubishi TV 0093, 0150, 0178, 0019
JVC VCR 0067, 0041, 0008
JVC DVD 0558, 0623
Hope it may help you;
Regards,
VOTIT
4helpful
2answers
Bell Expressvu 2700 satellite receiver av inputs
had my 2700 reciver unpluged for awhile now can't my channels back can you give me any idea how to fix this
6419ctb how to use av inputs
i needs the codes for the tv please
2answers
No code for expressvu
If you have tryed the auto searce mode, that means you tryed every code inside the remote, and if it didnt hit, Im sorry to say your out of luck, as this remote, as I understand from the spec sheet, is not a programmable or learning type remote.
Top One For All Televison & Video Experts
ExpressFiX
ExpressFiX
ZJ Limited
ZJ Limited
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
