Question about Exercise & Fitness
When I turn on says stuck button
When I power up says stuck button treadmill is almost brand new can't do anything with it
    Top Expert:
  • 12,223 Answers
Reset the treadmill, follow this step and fix it. Merry Christmas
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Posted on Dec 18, 2013
ercupa190
ernesto cuadra
  • 12223 Answers
SOURCE: Treadmill buttons don't work right. TV won't turn off. Treadbelt won't run.
1) Try to reconnect the plug between console and pcboard very well.
2)Clean the contacts with special contact cleanear( radio schack or computer store) with carefully only the buttons, if you can open the cover better.
3) adjust the Sensor SWITHC.
4) Look for any wire loose, or making bad contact, or break wiring( continuity) test the fuse and breaker.
If after you did those steps, and the problem persist, the console board is faulty.but first change the sensor switch, you must be shure after adjustment.11_18_2011_12_23_17_am.gif
Posted on Nov 18, 2011
Horizon Treadmill Ct5.1 turns on, displays nothing and beeps nonstop
If you wish to get some details about treadmill repair ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Nov 26, 2016 | Horizon Exercise & Fitness
I can't find the reset button on my life fitness T7-0.
The pan has to be removed to get to the reset button on mine, I have the same model
If you need further help, I’m available over the phone at https://www.6ya.com/expert/michael_2094e122cc46f24c
Sep 27, 2017 | Life Fitness T70 Treadmill
System check failed
  • Press the "On/Off" switch to turn the treadmill off.
  • 2Unplug the power cable at the bottom, base of the treadmill.
  • 3Push the safety switch in.
  • 4Plug the cable back into the treadmill and set the "On/Off" switch to "On."
  • ssincerely. Merry Christmas.
    ERNESTO CUADRAmanagua, nicaragua
    Dec 26, 2011 | Tunturi T80 Programmable Treadmill
    Nov 17, 2011 | Exercise & Fitness
    None of the touch buttons work. Fans, volume, speed, incline etc etc. The only two buttons that work are incline buttons 6 & 7. Power comes on and key turns on and off though. Can anyone advise??
    sorry but i dont have a solution for you!! i bought the t9ci back in nov of 2008, like you none of the buttons worked had to wait till march of 09 for nordictrack to send me a reprogram card, which did not fix the problem. i then recieved a new console, in april 09, which stopped working in feb 10. a service tech came out and had no clue, so the sent another new console which did not work. in march 10 they sent a whole brand new treadmill, and when i got on it last week the console was not working once again!!!!!!!!!!!!! i hope you dont have as many problems as i did
    Nov 05, 2011 | Nordic Track NordicTrack T9 ci Treadmill
    Have a new balance 1400 treadmill. when i power it on the screen goes blue and it will not doing anything.
    Does the screen turn on (blue) and then go black or does it stay blue? Mine has a similar problem where when the main power switch is flipped, it lights up, shows the initialization screen, then goes dark. Pressing any button on the console does nothing. I opened the console up and suspect one programmable microcontroller is bad. I'm going to see if I can get that part from FitnessQuest instead of replacing the whole board.
    Aug 28, 2010 | New Balance 1400 Treadmill
    Exercise & Fitness Logo
    197 people viewed this question
    Top Exercise & Fitness Experts
    Treadmill Repairs...
    Tom Chichester
    ray gallant
    Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
