I have a babylock bl 4000 sewing machine. I need the factory settings for the tension and how to thread the machine. also need info on how to put the bobbin in.
My babylock 1556 bobbin thread is too loose when sewing, how do I get that tightened up?
I found that the tension setting of 1 worked. The main problem was the machine had thread wound around behind the bobbin. I had to take the plates that are under the foot out, clean out the thread, oil the machine and use a spool of thread that had more weight than the little spool I was trying to use.
Baby lock not picking up thread from bobbin. and neddle when going down is on the outside of the bobben,is that correct ,
