I do not have a service manual for this dishwasher - it was in the property already. I wonder if I should be doing routine maintenance. It is not distributing dishwashing powder or cleaning dishes sufficiently. Should I be adding salt? How can I clear any blockage? The upper spray arm does not seem to be able to be removed for cleaning.
I have used this before and it works great! Dishwasher Majic. Sears' site is down I was going to post a link to it but I found this one instead. I work on all types of used dishwashers and It returns the inside to "like new". The short video link I am sending to you will tell you how to use it and I learned something myself by watching it...you can get it at wal-mart! Good Luck and write back with any additional problems!
P.S. Dont remove the spray arm when you use this. If you want you can remove the spray arm and spray some slightly pressurized water into the core of the spray arm to try to push out any buildup that will sometimes get in them and then run the unit with dishwasher majic and spray arms in place.
oops I forgot to paste the link...here it is...
http://www.expotv.com/Dishwasher-Magic/2...
