After calibration the treadmil stopped at 12 incline and will not go bsck down.
Please follow this steps and fix it. Merry Christmas
1 )Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill. ·2
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
·3
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset
SOURCE: I have a Nordic Track EXP1000i Treadmill. The
I know it's been months, but, if you still have this problem try this: 1. remove the philips screws holding the motor/belt/electronics cover on: you can lay the whole thing on it's side and remove them from the bottom. there's two in the front and two on the sides.
2. Obviously, unplug the unit! before doing anything. lay the unit back on it's feet (normal position)
3. Find the incline motor assembly. it will be int he middle of everything. black tube thingy.
4. take a cordless drill with a flat head screw driver bit, and turn the incline motor CCW. until the bed is flat.
5. what what I have read, you should shop for a new incline sensor. these fail before the motor does.
SOURCE: My treadmill is stuck in the max incline position
If the incline moves but only just a bit, it could be a problem as simple as the gearbox on the motor being jammed. We remove the motor from the treadmill, reconnect the wiring, and then try to run the incline motor outside the treadmill. Many times, this will unjam it if that is the problem and then reinstalling it in the treadmill will get it to work. If you have the same problem or it doesn’t run outside the machine and you can hear it try to work, you need to replace the incline motor.
SOURCE: My Nordictrack treadmill seems to
it is trying to calibrate itself, let it go the whole way up and then down without interrupting it. Then it should be fine.
SOURCE: my treadmill is stuck on
incline motor is bad or needs calibrated, try this
1. remove safety key
2. press and hold the speed+ and stop keys at the same time
3. Put the safety key in/on and release the keys
4. press stop once
5. hit the incline + arrow and let the incline go the whole way up and down
6. remove safety key and try
SOURCE: My Nordictrack commercial 1500 is stuck at 12%
need to flip side and with a wrench 1 / 2 or 9 / 16 loosen the screw of motor base and try to press the down key and if so work you should Lift motor replacement
