My fisher & paykel smart drive 703 7kg washing machine was working fine but now it will start to fill up with water then stop and restrart all over again can anyone help me out with this problem
i was just wondering if this is the problem is it hard to fix and would it cost much
could you help me please if anyone roughly knowsthanks
You can't post conmments that contain an email address.
It sounds like you have a faulty Out of Balance Micro switch(the machine now thinks it's always out of balance) you'll find this under the motor controller module (main computer module) in the top of the machine on the righthand side. Anymore questions feel free to ask. cheers
If your technically minded it's very easy to fix and you can get a new Microswitch for about $10 I believe cheersIf your technically minded it's very easy to fix and you can get a new Microswitch for about $10 I believe cheers
It won't spin until all the water is drained out. The drain pump may be blocked or faulty. Fix the drain pump fault first then deal with the filling issue. They will not be related.
the buzzing noise is the pump trying to work, but it cannot due to a blockage. unplug the washer and you can lean the washer backwards and remove the pump to unblock. the fill error is probably unrelated, and is an inlet valve issue.
You need to check your lid switch & out of balance switch for
corrosion and replace if faulty.
Your out of balance switch is under the big yellow motor controller
OOB switch Is where the grey plate is on this picture.
Hi just found your posting.Do you still require help?Sounds like a lid switch fault to me.Does the machine beep when you push the start button.Please reply for further help.Looking forward to your reply.
A failed inlet valve is not uncommon in F&P machines. The hot valve is different to the cold one, so don't exchange them. Not a big job for a tech to do in-laundry. Good luck....Nomess
If there is power and all your lights are lighting up but you get no responce from the machiene eg no spin, water filling, wash cycle or drain then it will be the sensor for the lid it will have coroded but this is an easy fix , I hope this helps
thanks
