SOURCE: protect mode
Press reset button (small circular button need something with a point) to the left of the 1 channel
SOURCE: kdc-mp2032 how do i get it out of protect mode
Check your speaker connections, you've got a short. Check for loose tape on any connection. Fairly common problem. If your unit is Code Protected.. Try entering the code first, If you have a code, keep it handy, any time you jump start or loose power to the radio, it needs to be re entered before it will work again. Hope this helps
SOURCE: Kenwood KDC-MP732 CD Player in protect mode how do
Protect Mode (Blink): The speaker wire has a short-circuit or touches the chassis of the vehicle, and then the protection function is activated.
Solution: Wire or insulate the speaker cable properly and press the reset button.
Here is a copy of the Instruction Manual for the Kenwood KDC-X790 and KDC-MP732.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
