52 grinding noise from under car . not sure if it
Hi, When a grinding noise is detected first locate the area of the car it is being generated from. Most grinding noises will be being generated while driving, if you are having a hard time detecting the location of the grinding sound, have a helper ride along in the rear seat to give a new perspective on the origin of the grinding noise. A grinding noise can be generated by many things from worn out brake pads to axle bearing failure. Once a grinding sound has been detected action must be prompt. Grinding in most cases is telling you something has failed or is failing.
It can be as a result of worn out brake pads or shoes, check your engine and transmission mount, check for axle bearing failure, check your power steering system for leak...
Take care
