I NEED ASSISTANT TO DISABLE WRITE PROTECTION.
With Private Zone's applock, I can lock up my Facebook, WhatsApp, Clash of Clans, Messenger, Gallery and other important apps which may leak your privacy. And I can also customize my lock mode which allows me to lock different apps under different circumstances. CM is also a good choice, but I think it isn´t smart enough LEO Privacy Applock Hide Safe Android Apps on Google Play
You can use Google account to recover it OR secondly you can factory reset phone.
Reset Lock Pattern
Step 1
Power on the Infuse and enter any incorrect lock pattern. The message "Sorry, try again" displays. Step 2
Tap "OK" at the prompt, and then enter the incorrect pattern four more times. Step 3
Tap the "Forgot Pattern?" button. Enter your Google Account information, and then tap "Sign In." Step 4
Enter your new lock pattern, and then touch "Continue." Alternatively, tap "Cancel" to enter a new pattern later.
Factory Reset
Step 1
Power off your Samsung Infuse. If it does not turn off, take out the battery and reinsert it. Step 2
Press and hold "Power," "Volume Down" and "Volume Up" together. Step 3
Let go of all the buttons when the Android logo appears. Step 4
Press "Volume Down" to highlight "Delete All User Data," and then press "Power" to select the option. Step 5
Press "Volume Down" to select "Reboot System Now," and then press "Power" to reset the Infuse to its default state.
SOURCE: Forgot my password
Hi everyone
There's good news and bad news. The good news is that you might well
have forgotten that the default password on the Samsung SGH-D500 phone
is 00000000 (that's eight zeroes). The bad news is that if
you've changed it to something else and that's what you've forgotten,
you might well need to take the phone in to a service center to have
them help you break it back open.Please put a good rating on my profile.
Kind regards
Dustin Ellse
SOURCE: forgot my csl i-200 phone lock password..im using
my CSL blueberry phone model i6100 phone lock
SOURCE: hepl me 2 unlock my mobile
SOURCE: I forgot my phone lock code for my lg chocolate
okay you need to type the last four digits of you phone number which was the original code upon purchasing the phone, then press the pound button right after. type the four dgits and then immediently the pound sign. you might have to try it a couple of times before you get it. this is how many people are able to use locked phones that are stolen. my friend who works at a verizon fios taught me this when i locked and forgot my passcode.
SOURCE: i forgot the phone lock password for my Samsung Memoir
Only way to reset it is to flash your phone. Search internet for flash files and flasher. After flash your phone will be set to default one!
227
views
U just istall p.c. suit of sonyerricsson and take backup of ur data,, then u need to flash ur handset from sony erricson service centre.
Trying to find my lost s pin to my Samsung tab2
How do I unlock screen pattern if I forgot my pattern on Asus zenfone 4
If you forget your pattern:
1. After you fail to unlock the screen in pattern for 5 times (4 dots at least), there will be a text sign of "Forgot Pattern?" appeared on the lower-right of the screen.
2. Tap "Forgot Pattern?" and then enter your Google account and password saved in this phone to disable pattern lock.Note: If you do not log in your Google account or the device is not connected to internet before the phone is locked, you will need to perform factory data reset in DROIDBOOT mode to solve this problem.
If you forget your PIN or password:
1. To reset your PIN or password, you need to in advance log in your Google account in your device and have your phone connected to Internet as well as Location function enabled.
2. Then, visit website below: https://google.com/android/devicemanager
3. Choose your device that you want to reset PIN. After your device is located, tap "Lock" in the wondow and reset your PIN.
How to change a lock screen password that I have forgotten
Setting up a password protection on a smart phone, was to prevent anyone without password to be able to access your data. Now you forgot the password, you are excluded to the information too.
If there was a general code to unlock every password, that would make the security a farce and worth nothing.
How do I unlock
2. Select "Forgot pattern" and enter your email account username and password.
3. Make sure you use the same account that was used to activate the device and double check the password by logging in to that email account in a browser.
4. If you don't have access to the original email account, you will need to do a hard reset and loose your settings and apps on the devcice. The data on the memory card will not be wiped though.
Note: if you can't remember your email password, you will have to visit the email service support page to get it reset.
also, see here...
http://www.androidtablets.net/forum/android-tablet-usage-tips-tricks/6280-forgot-your-unlock-pattern.html
or here... http://mytabletguru.com/forgot-password-pattern-unlock-of-android-tablet/
I forgot my lock screen password to my xtreme tablet what do i do
Model q8(a-1) forgot password
Samsung sgh f480 privacy lock forgot password
2012 question doesn't need a spammer like YoYo (AKA Sammi)
I forgot the security code for my Samsung Eternity
YoYo is a spammer on FIXYA, permitted to post the same post infinitely for some unknown reason.
Top Samsung Cell Phones Experts
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
