Have a self-starting, self propelled Toro walk-behind lawn mower w/a Briggs & Stratton engine, 190cc, about 5 years old. I ran it out of gas & now it won't start and because its self starting can't find a choke or pump primer - it was working perfectly so don't think its spark plug. One suggestion was to buy a new gas tank lid that has a primer bulb in the actual screw on cover as this is common, you agree ?
SOURCE: My Toro lawn mower runs
The following website has a lot of information about Toros:
http://www.ehow.com/toro-lawnmower/
You've done most of the things, except you didn't mention ceaning the air filter, but perhaps you incuded that cleaning the carb. You could have a cracked gas hose,
This page might be of help to you also:
http://www.ehow.com/way_5890404_toro-lawnmower-gets-hot.html
Good luck, and hope this helps you out.
SOURCE: I have a Toro 20" self propelled, electric start
I am strictly Briggs&Stratton. They are hard to start when the fuel tank is half empty. Clean the plug and air filter.
SOURCE: My parents have a self
Does the mower die right away (cuts out) or does it sputter to a halt. Sputtering out would indicate a fuel problem. If it just cuts out when hot, then more likely an ignition problem. Your coil may need replacing. Take a close look at the coil wire (spark plug wire) and its routing. Make sure it's not touching part of the engine where it's heating up and has caused a "leak" to ground it out when it gets hot. If all is well then check your spark when the engine is hot and cuts out. Make sure you have a very good blue spark and not a weak one (check it cold first and then compare!). Again, indicating a possible ignition coil problem. Hope this helps and best of luck to you.
James
SOURCE: toro self propelled lawn mower dies after an hour
maybe u have to much oil in it or there mite be a stone in the carberator or petrol tank thats blocking the petrol ?
