SOURCE: Loud noise thourghout the cycle
I would have the counter-balancing system checked for proper motion.
SOURCE: Maytag Performa washer Waterlevel/agitator problem
CHECK your stand pipe hasn't fell over (the one the drain hose goes to when emptying)If not,Either the pressure switch is broke or there is a hole or split in the pressure switch rubber hose.This switch stops the water when it reaches required level.
SOURCE: Burnt Rubber smell and spin cycle didn't work
the main motor needs to be serviced , sounds like the couplings broke , hope this helps , AJ
SOURCE: Maytag Neptune Tl Spin settings
HELP I HAVE THE SAME IS ISSUE AS\r\n
http://www.fixya.com/support/t1457953-maytag_neptune_tl_spin_settings
My Spin cycles keep cycling through, it seems to wash fine but is always beeping and changing through the spin selection.
Is it the control board, ribon cable, membrane??
HELP!
Nate
SOURCE: Maytag Epic Z front loading washer spin cycle very loud
your bearings and seal need to be replaced.
