Washing Machines Logo
m
mohaned abdelmoniem Posted on Dec 19, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hitatchi sf p150jj
Can it work in 50 hz instead of 60 hz
Graham Bagwill
Level 2:
  • Expert 102 Answers
  • Posted on Dec 21, 2013
Graham Bagwill
Expert
Level 2:
Answers
102
Questions
Helped
30281
Points
193
Some washers can but the speeds will be slow unless it is a digital motor control.
1helpful
I have a FG5700A McCulloch Electric Generator and the capacitor is bad. It is a CBB60 - 26uf - 500VAC- 50/60 Hz. Where can I get one of these?? Or a capacitor that will work? Thanks!!
Lots of places :>)
KENOWA TRUE LIFE 26uF MFD 450V 500VAC 50/60HZ ...
picclick.com > ... > Parts & Accessories > Other
Product Description: Premium UL Listed Metalized Polypropylene Film (MKP) 26uF 450VAC 50/60 Hz Generator Capacitor AVR for Kenowa & TrueLife Branded ...
generator capacitor - Amazon.com
www.amazon.com > generator-capacitor
Results 1 - 16 of 667 - POWER PRODUCTS CBB61 Generator Capacitor 35uF 34uF 32uF 400VAC 450VAC 50/60 Hz 40/85/21 SH. 5.0 out of 5 stars 5.
Kenowa True Life 26uF MFD 450V 500VAC 50/60HZ ... - eBay
www.ebay.com > ... > Parts & Accessories > Other
Universal 26uF MFD 300V 350V 450VAC 500V 50/60Hz Generator ...
www.cafr.ebay.ca > ... > Other
Translate this page Universal 26uF MFD 300V 350V 450VAC 500V 50/60Hz Generator Capacitor ... Capacitor CBB61 CBB60 36uF 35uF 33uF 31uF 400V 450VAC 50 Hz 60 Hz ...
capacitor 26 uf in Automotive ' eBay
www.ebay.ca > sch
Find capacitor 26 uf from a vast selection of Automotive. Get great ... Kenowa True Life 26uF MFD 450V 500VAC 50/60HZ Generator Capacitor AVR ... JKD CBB61 45uF 42uF 40uF 38uF 36uF 450V AC 50Hz 60 Hz Generator Capacitor AVR.
How to convert 50 hz waterpump to 60 hz??
you cant but difference between 50/60 hertz should not stop in running does the rest of machine work ok does it wash spin if so I would be lokking for wires of jammed pump ect
Ordered vv20 portable 220 volt heater for my american home. question- will the heater work on my 220volt 60hertsystem with no damage to the heater. -heater came from great britain
If it says "100-240V, 50/60Hz", it will work anywhere with the correct plug.
Frequency ("cycles per second")is no problem usually as most things work on 50 or 60 Hz 60 Hz converts more easily to DC than 50 Hz , there's enough tolerance you can ignore frequency. Any clocks keeping time from frequency must have a sine wave.
Need to transform 120v power to 240v
Bad news:
UK has 50 Hz electricity, and appliances are rated for local power..
Any appliance made for US market is rated 60 Hz.
50 Hz and 60 Hz electricity are different.
Look at label on your mixer, and then look at labels on local appliances. You will see 50 cycles or 60 cycles. Rarely appliances are labeled 50-60 cycles.
http://www.worldstandards.eu/electricity.htm#voltage
http://waterheatertimer.org/See-inside-main-breaker-box.html#Hz
http://waterheatertimer.org/What-is-3-phase-electric.html#120-240
Hz Hertz or cycles or frequency is number of rotations the electric generator turns per second.
Some appliances are rated 50-60 cycles and will work worldwide.
However most appliances are rated 50 or rated 60 but not both.
60 cycle motor will not perform as expected when connected to 50 cycles. And might overheat.
Generally, most motors can be converted to different voltages by taking motor to motor shop (if you can find one these day)
However electronic controls cannot be converted between 120V and 230V, nor will 50 Hz electronics work with 60 Hz power
Sorry Sue.
Buy another mixer.
Business will benefit from surge of consumer buying.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
1helpful
I recently purchased an Audiovox Clock Radio CR20 from the USA on a visit to that country. I am back in my home country India and started using the clock radio. I find that the clock is not keeping correct...
The reason of your problem is that your local mains frequency is 50 Hz and when you use 230V to 120V converter, this simple device can not convert frequency only the voltage. Your clock is synchronized to the mains frequency which is 50 Hz instead of 60 Hz and the clock goes slowly. It is late (60-50)/60 ---> 10 minutes in every hour.
I am sorry but I think your problem can not be fixed. ( It would be possible to convert the frequency but the cost of this kind of device would be higher than the value of this Audiovox)
Thanks.
gylacz
1helpful
The time falls back by about 10 mins a hour? I am using it in India with a 230/110 adapter but working at 50 Hz instead of 60 Hz Is the timing derived from supply freq? i don't think so but just asking ...
The frequency of the power supply line IS where the clock obtains it's reference...it is divided internally to provide the timing for the microprocessor...the only way to make it work properly to my knowledge is to plug into 60 hz supply.
Dryer timer counts off to fast
The only thing that I can think of is that you are using a dryer intended for Europe in the US. While they both run on 220V, the timer motor will be specific for the frequency of the country. The US uses 60 Hz. Europe uses 50 Hz.
To keep the explanation simplistic, your timer motor expect 50 electric (frequency) "beats" per second but instead is getting 60 beats per second. Your clock is turning an extra 12 seconds every minute.
Playstation 3 for europe
All the machine manufacture for Usa work on 110 volt 60 hz and the format is Ntsc.You should check availability on line about region Format like NTSC-PAL -PAL2 SECAM and which country are using the same, and make sure the hz is 50.Most of the new Game system support Dual Voltage But not the Ps3.You need to let your seller check on the machine tag to make sure everything is correct like 220v 50 hz.
Fabio
Top Washing Machines Experts
john h
