Question about Hitachi CP-X328 Multimedia Projector
My projector said the lamp needed fixed. So I bought new one and it still said the same thing
    Top Expert:
  • Hitachi Master
  • 12,223 Answers
If you replace the old by new one, and NOT light, the problem is power unit(ballast) inside , you must go to the repair shop . Merry Christmas
Posted on Dec 20, 2013
6ya staff
SOURCE:
Sharp projector Bulb replaced but still won't work?
check the ballast
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Nov 08, 2012 | Sharp Projector Lamp For Xv-z90 Xv-z90e...
Toshiba TLP projector identifiation part
You need to check lamp again, it may be not well mounted.
Mar 28, 2008 | Toshiba TLP S30 Multimedia Projector
I replaced the lamp on my sharp dt100 projector and now it will not turn on
Have reset the lamp hours after installing the new lamp? If, not the projector has treated the new lamp as old lamp & refusing to light further. So, reset the lamp hours to zero. To reset the lamp timer do as follows. Plug the power cord into the AC socket of the projector. Switch ON the power of the socket. (not projector) While pressing simultaneously MENU/HELP, ENTER & DOWN (button near MENU/HELP) on the projector, press STANDBY/ON on the projector. "LAMP 000H" is displayed, indicating that the lamp timer is reset. If this does not correct your problem then the problem lies in other area. Let me know so that further I can provide you solution. Above things are preliminary.
Aug 06, 2011 | Sharp Office Equipment & Supplies
I have a sharp xg-c55x. I put a brand new lamp. It worked once for about 20mins. Since then it starts warming up & then it turns off. How do i fix or reset? Thank you
Have reset the lamp hours after installing the new lamp? If, not the projector has treated the new lamp as old lamp & refusing to light further. So, reset the lamp hours to zero. To reset the lamp timer do as follows. Plug the power cord into the AC socket of the projector. Switch ON the power of the socket. (not projector) While pressing simultaneously INPUT, ENTER & UNDO on the projector, press ON on the projector. "LAMP 100%" is displayed, indicating that the lamp timer is reset.
Jul 07, 2011 | Sharp XG-C55X Multimedia Projector
I just replaced my bulb on the toshiba tdp t45u projector and the red lamp light is still on and the projector still wont come on? how do i fix?
Check out the Power supply to the lamp . It must not be high . . Check if the voltages are correct to the lamp's unit and it's PCB [printed circuit board]. I recommend using a service manual .
Here is how to replace a projector's bulb correctly :
1:Make sure that your power switch is off and that the power cord is unplugged from the electrical socket.
It is also wise to unplug any other cables and label them in order to restore them in the right way once the lamp is replaced.
2:In order to see the lamp, remove the access handle on the outside cover. You may need to use a screwdriver.
3:Pull out the used lamp and clean the relevant parts using micro fiber products and not paper.
Please note that in some projectors a small inside filter should also be replaced.
4:Insert the new lamp into the projector carefully avoiding touching the glass of the lamp itself.
Touching the lamp will deposit skin oil that will likely damage any new lamp during use.
5:Reassemble the access panel, replug the cables and power up the projector.
Things You'll Need:
new projector lamp
screwdriver
micro fiber duster
Warning:
avoid touching the bare projector lamp
I hope this will help .
Apr 11, 2010 | Toshiba TDP-PX10U DLP Projector
Projector won't turn on and LED Temp/Lamp flashes! has new lamp
I wish you had received a relevant answer to your question, as I'm experiencing exactly the same thing here. Not sure is this site notifies people when they get responses, but did you ever figure out what the problem was?
Apr 08, 2010 | Optoma MovieTime DV10 Multimedia Projector
Replcing bulb
There is lamp cover at bottom of projector, unscrew it, take it off, you will see Lamp inside that also fixed with screw, unscrew it and take it out, place new lamp and put thing in same way.
Jun 09, 2009 | NEC MultiSync LT280 LCD Projector
Sanyo plc xu 40 lcd projector problem
not only reset the timer is good enough
u must use serive cable to disable the shut off function
and technically reset the system
Jul 09, 2008 | Office Equipment & Supplies
Projector Lamps for the Toshiba TDP-MT8 DLP
Have you contacted Toshiba? They will sell you a new fan. It is possible the power supply has a problem. Bulbs usually have a 90 day warranty. Contact where you bought the bulb. Prices are dropping rapidly for new projectors. Yoiu can buy a new oen for under 500.00.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Aug 07, 2007 | Toshiba TDP-MT8 DLP High Definition Home...
Lamp
I have the CP-X275W that did the same thing. The ballast was bad and I fixed it with a $5 switching regulator. The CP-X327 has the identical ballast.
Details:
The High Intensity Discharge Metal Halide lamp suddenly failed to light up. A new lamp was installed and would not light up either. The fan ran and the lamp LED flashed after a few minutes. Voltage to the ballast module was 368VDC. The ballast did not pulse.
Ballast# PS-226-LS-210 was bad. Hitachi Part# HA01101 has been discontinued and the new part number is HA01102. It was $210USD at Vance Baldwin or $221USD at Part Solver.
The FET series (TR1,5,6,7,8,) seemed good: (drain-source resistance=5Kohm). Bought an identical projector on Ebay to do comparative multimeter measurements. Found resistance differences in IC01 (STRG6153). Swapped good part to bad projector, and it worked. This is a 5-pin Sanken brand switching regulator, US$5 at www.electronix.com. They have the STRTG6153, which is compatible, and may be better. The bad one removed from the circuit measures 15Kohm on pin 3 to pin 5 and the same 15Kohm when the probes are reversed. The good one measures 18Mohm and infinite when the probes are reversed.
If you would like me to fix it for you and clean all your optics, I can do it for $150USD plus $25 return shipping. Contact Chris at chris_goulet@yahoo.ca.
If you have a new lamp for sale I would buy one for $100USD.
Good luck.
Dec 22, 2006 | Hitachi CP-X327 Multimedia Projector
Hitachi CP-X328 Multimedia Projector Logo
94 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
polytek
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
