LG WM2301H Washer Logo
D
Douglas Wilson Posted on Dec 20, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Water is leaking out
Can pour water into the area where the softener is place, few moments later it runs out of the side
Graham Bagwill
Level 2:
  • Expert 102 Answers
  • Posted on Dec 21, 2013
Graham Bagwill
Expert
Level 2:
Answers
102
Questions
Helped
30306
Points
193
Plastic housing broken, dispenser to bowl hose fractured. Soap powder has hardened in dispencer hose blocking same, needs cleaning out.
Frigidare top loading washing machine, 1995 model # GLMS174SAS4
I believe the softener is dispensed through centrifugal force when the machine is in the high speed spin after draining and before filling for the rinse cycle. I had the same issue on another machine. Use very hot water and a washcloth to clean out the softener cup. When adding softener at the beginning of the load, only add the recommended amount and then fill the remainder of the cup with water.
2answers
I get a whistling noise i think is coming from throttle body
Your whistling is quite possibly a vacuumn hose leak on the passenger's side, top of the engine. Look closely at the hose connections coming from the PCV. Small holes can develop in these vacuum line connections, and you will experience a rough idle, as well as the "whistling" noises.
I have a Rheem 40 gal. tank that is leaking water front the top where the vent stack is. It is pouring out. Can it be repaired?
A leaking water heater cannot be repaired, assuming it's the tank leaking and not nearby water pipe.
http://waterheatertimer.org/Water-heater-leaking.html
First thing is to protect your property from catastrophic tank failure where tank ruptures and water runs until it is shut off:
Tanks are under pressure when they are hot.
Close cold water shut-off located above tank.
Turn control knob to 'pilot' so pilot is lit but burner will not turn on.
Open hot side on tub for few moments to relieve tank pressure.
Now your property is safe.
You need a new water heater.
In mean time, gas water heater makes 41 gallons hot water per hour.
Shower used 5-9 gallons hot water.
Bath uses 10-15 gallons hot water.
You can turn on water heater for short stretches and limp by until you get a new heater.
Steps for installing gas water heater:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
3helpful
Maytag side by side fridge freezer leaking water
Your drain plug within the evap area of the freezer is frozen, turn frig off, let sit for day or two with doors open. Once all ice has melted then take rear freezer evap cover off and pour water into try and make sure it drains, if not then unplug drain. This is usually caused by a defrost heater bad or unit not going into defrost when it's supposed to, may be main board.
5helpful
2answers
Water leak on fwd and back passenger side after every rain storm
pull your carpet up near the leak area and look for muddy body seams. it is possible one of the factory body seams are leaking- possibly in the cowl(under wipers) area, especially if it leaks when the car is sitting. there will be dirt/mud around the seams that are leaking. also you can check door seals by running the car on HIGH DEFROST with all doors and windows closed. spray around with a 50/50 soapy water solution. obviously bubbles will form around your leak.
Water Pools Up in the Fabric Softener Area
have you dis assembled the dispenser drawer and cleaned out the sections. the top covers slide off their areas standpipe.
1helpful
3answers
We have a Maytag front load washer Model MAH 4000 AWW
tHE PROBLEM IS YOU NEED TO CLEAN YOUR SOAP, SOFTENER AND BLEACH DISPENSER, REMOVE THE BLEACH AND SOFTENER DISPENSER TRAY, AND YOU WILL FIND THAT IF YOU HAVE BEEN USING LIQUID SOFTENER, THAT IT HAS GUMMED UP AND CLOG THAT AREA AND IS CAUSING SPILL OVER. WHEN THE WATER IS POURED INTO THE TRAYS TO DISPENSE THE BLEACH AND OR SOFTENER.
7helpful
3answers
Kenmore Front Loading machine, does not drain the fabric softener
We had the exact same situation with the fabric softener not draining and here is how we fixed it. Turn the water off first, then remove the water lines that bring water into your washer. (They are near the top.) There is a screen in the end of the line, do not remove it, but take an old toothbrush and brush the gunk out and clean it as best you can. Do both the hot & cold sides. The screens keep any debris out of the washer, so after a while it collects and slows down the water intake time (has your washer been slow to fill also?) Screw back the lines, making sure to put the hot and cold back as they were originally, then test that they do not leak. Put your washer back in place and viola - problem solved! I hope this works for you, and good luck!
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
