C
Chase Peralta Posted on Dec 20, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It has vertical lines when it starts up - Dream Vision DreamWeaver Multimedia Projector
ernesto cuadra
Level 3:
Top Expert:
  • Dream Vision Master 12,223 Answers
  • Posted on Dec 20, 2013
ernesto cuadra
Dream Vision Master
Level 3:
Top Expert:
Answers
12223
Questions
0
Helped
4080538
Points
34431
Test the main PWB for colder joint and reheat 2) video signal en pwb faulty, test 3) test the cables for dusty, oxide, corrosion.
Merry Christmas.
My Sony KDL-60EX500 started having picture problems. Light purplish vertical, squiggly
Hello Dear
please check coils which are very near to LVDS jack these are open these are interface coils between panel and main board some are open
Thanks
M Nasir
How do I remove three vertical colored lines from my Television. One vertical line is green another is red and the final one is blue.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Canon image runner c5800 printing vertical lines
have you ran a test page , the test will take about 30 sheets of paper it will test everything and will correct itself
good luck
1helpful
One day my tv started having white lines in various places, then one day the scrren went white but still has a small line across the top that works fine
The problem is "Vertical Over-drive" and the white lines are vertical retrace lines. What has happened is a component failure between the vertical oscillator and the vertical driver circuit. The component is usually a capacitor that is leaking and allowing voltages to appear where they shouldn't be.problem component is leaking and allowing DC voltages to appear where they don't belong. It's causing the vertical driver transistor to run "flat out" and will ultimately burn out the transistor from internally generated heat.
Hope this help....
3helpful
3answers
Vertical lines on screen
1. Frist on the BURN MODE.
2. Check whether same
Vertical lines on screen ?? 3. If yes ..?
4. Then change the LOGIC BOARD or PDP
Screen distortion
Is it a clean vertical line or a fuzzy vertical line? It could be as simple as a cleaning.
Top Dream Vision Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Dream Vision Office Equipment and Supply Expert? Answer questions, earn points and help others
