Its not doing anything except clicking from the front of machine not washing or even moving
It sounds like the rotating program controller has failed. It is telling other parts of the machine to do things as part of the wash cycle and the signal is not reaching them. This is an expensive part to replace. Get it fixed under guarantee if its new. If its old replace it, but do not buy a Hoover, they are very cheaply made and fail a lot. If you want a cheap one buy a Zanussi.
SOURCE: Hoover Vision 1600 drum not spinning?
I have similar problem with same model unit, found brushes on motor worn to point copper contact is hitting and scoreing commutator. Easy checked, ensure power completely disconnected, lie machine on side and gently rotate drum looking in side the motor. The commutator is what looks like a circular block of copper segments which will rotate with the drum and should be evenly worn and coated with carbon from the brushes. If you see a clean copper area, usually in the center, then the brushes are worn down below workable levels. Suggest replacing should resolve problem.
SOURCE: My front-loading Hoover washer/drier (Softwave
Door will not open if it has water in it.
Lay hose down to get rid of water, then you can open door.
Try the spin with no water in, if it spins, then you have a draining problem
SOURCE: Where is the filter on a Hoover softwave AC 270 washing machine
hi there,
here are top load washing machine parts are located.on figure you can locate where the filter was located,may be this will help you.,hope you can solve but if still not run,feel free to log in to fixya we are here to serve you better.have a nice day,rate my solution.thanks a lot.
