Hi, how can I connect an antenna to my Sony BRAVIA KLV-40U100M? There's no co-axial connection.
SOURCE: There is no picture and no sound on my sony bravia
Check the U24 (CPU reset IC) on the "A" board. It may be burned. If you have a DVM (voltmeter) check for 3.3V across SW1 connections near this device. If you don't have 3.3V, U24 is bad. This part is not available from Sony. The TV may work if you just remove U24 from the board. I posted this fix on Agoraquest also, you can read more there (I'm "Roundabout" on that forum). Hope that helps
SOURCE: Sony Bravia KLV-40U100M-screen is distorted, overlay or various vertical lines
The resolution on this was to check the surge protector the television was plugged into. Once we unplugged and plugged into another surge protector, the screen went back to normal and the appearance was great. We believe this was due to one of the resistors within the surge protector may have become faulty.
SOURCE: Sony KLV-40U100M Screen replacement
I have the same tv with no power do you want to sell me your power supply?
SOURCE: How do you remove base
First remove the back panel from the set. Next look at the bottom and you'll see an aluminum bracket that connects the base to the frame of the set. Remove the four screws, replace the back and you're done.
