ViewSonic N1630W 16 in. LCD TV Logo
A
Anonymous Posted on Dec 20, 2013
How do I run channel auto scan
When I turn on the tv, it doesn't play anything and it says "please run channel auto scan." I also have a fios cable box hooked up to it
Andy B
Level 1:
  • Contributor 3 Answers
  • Posted on May 20, 2014
Andy B
Contributor
Level 1:
Answers
Questions
0
Helped
1316
Points
Press MENU, use left/right buttons to get to input, then select AUTOSCAN using up/down keys and SELECT/ENTER button. This will take a while, 3-5 minutes. When it finishes, it will default to channel 2. At t.his point, push LIST button to see all stations it found.UP/DOWN buttons will let you select station of interest.
1 Related Answer
Robert Johnson
  • 395 Answers
  • Posted on Jan 17, 2008
SOURCE: Please scan channels
try hitting the input button or go to channel 3. the sat box can only output to channel 3 or 4 or if using Dish network try channel 66 or what ever the channel it outputs. it also can output via video cables so check each video setting on the set. make sure the box is on first.
2answers
I run the auto scan and it is picking up 0 channels and say to please run auto scan
Where is your antenna hooked up? Thru a cable box? Direct to tv? Completely describe setup, maybe post photos
I have an Element ELEFT502 50 HD Digital tv. I am trying to connect my cable line to the TV but cannot get the past the auto scan screen
put the co axel cable in the back , bypass this tv programming stuff put your tv on channel 3 or 4 and use the cable remote , no tv channels just cable
How do I run channel auto scan on Calypso TV
try going to settings ,menu then hit present or auto scan
1helpful
2answers
It ask to please run channel auto scan
just press the key that displays on the screen when it ask run channel auto scan or go to menu and channels find auto scan then press enter
1helpful
Can't get rid of "Please Run Channel Auto Scan" stays on tv screen
for some reason it is not seeing you cable signal. you will need to make sure you have it set up for cable and not air. check your input options, like tv/av/hdmi/ ect hope this helps
When setting up a new TV, it keeps telling me to "Please run channel auto scan." But it also states that if I sellect Cable/satellite, that the tv does not need to run the auto scan. When you...
you need to select cable from off your remote and run the auto scan.even if it says you does not need to run auto scan still run the auto scan.good luck.
1helpful
How do i hook up my 16-454 to my verizon fios cable?
I am not sure what a FIOS use, but I was able to split my cable connection and was connect my regular TV AND portable tv with the cable.
IN YOUR CASE:
Look at your fios set up box, behind the box, there should be something that would say "TO TV" or "VIDEO OUT" or "TO TV/VCR"
Usually, the cable coming out from there goes to your regular TV. So instead of your regular TV, you can connect that with your portable TV.
AS FOR MY CASE (Having 2 tv's),
1. I removed the cable that is connected to the wall (RF IN or From WALL or CABLE IN).
2. I hooked that end to the "IN" part of a 3 way splitter
3. I bought a short cable and connected one end to the Cable Box and the other end to the OUT of the splitter
4. I bought a longer cable and connected one end to the portable TV and the other end to the OUT of the splitter.
5. Then I turned on the TV and pressed MENU
6. I clicked the right arrow until I see ANTENNA. I pressed the down button to choose CATV instead of AIR.
7, I did auto scanning.
My portable TV now has the basic channel while the big TV (since it is connected to the cable box) has the added digital channels. Nevertheless, it is great to have both so when I want to sleep, my hubby can just use the small tv
Top ViewSonic Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
