Sony KLV-S32A10 32 in. HD-Ready LCD Television Logo
P
Peter Rossi Posted on Dec 21, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sony PFM-42v1 I can not play certain digital channels, When I do tha window opens saying: This receiver has dertected that the HD TV or the digital connection to the TV does not support High-Bandwidth Digital Content Protection (HDCP). because
malcrat
Level 2:
  • Expert 68 Answers
  • Posted on Dec 21, 2013
malcrat
Expert
Level 2:
Answers
68
Questions
0
Helped
18709
Points
136
Some TV's can be connected to the internet and are then able to get software updates from the manufacturer. Look into that as a possibility.
3 Related Answers
Jason Morris
  • 362 Answers
  • Posted on Jan 20, 2009
SOURCE: Sony Bravia does not see my digital channels
Hi buck lite,
Your cable company is telling the truth, you have digital cable. When auto scanned for digital channels the tv is lookig for OTR(over the air) signals. These are broadcast signals you will need an antenna to receive. Depending where you are and the type of antenna you use you probably could pick up some digital channels. Let me know if this helps and please rate this solution. Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Anonymous
  • 197 Answers
  • Posted on Jun 09, 2009
SOURCE: Closed Caption not working on my Sony 40" Bravia LCD TV (KDL-40
turn cc on receiver
Anonymous
  • Posted on Jan 01, 2010
SOURCE: HDCP not compliant after hook up
We have hooked up our Sony HD TV Bravia Model KDL-46v5100. when we hook up the DVI connectores the message says not
HDCP not compliant, what does this mean???
My sony pfm-42v1 no pictue
turn it off for around 30 min..try it again, then let us know what you find...could be a control board issue
2answers
Where is the coaxial connection on the Sont PFM-42V1 model made in 2003
Look at the back of the tv. Bend down and then look up and you will see the coaxil connection and possibly other rca connectors as well.
2helpful
Sony PFM 42V1 Vertical black line
you have a bad lcd panel call sony they may help
7helpful
Sony pfm 42b1 negative picture
I have a Sony PFM-42v1 and it does the same thing, look in your tv menu for picture inversion, usually under screen saver. What it actually does is reduce the chance of screen burnin. By reversing the image it sort of resets the hot areas, brightest colours and the cooler areas being dark colours, switches them around ( negative ). This cools the hot spots and heats up the cold spots.
There should be a option to turn it off, mine and I guess yours as a default is ON, mine has the ON, timer and OFF options.
Hope this helps, please let me know if you need more info.
russell
Cannot even find where to plug to aerial point into the sony plasma flat panel display tv PFM-42V1
PFM-42V1 has no ability to receive channels through aerial / cable.
You can hook direct video cables from dvd player, vcr, PC etc.
Loss of the color Red....Possibley others on my plasma
If you are lucky, it could be an open resistor or defective IC. Otherwise, I see a new TV in your future as the Plasma display would cost nearly $5500 for the part alone. If the fireplace is used much, I would not mount a TV above it, especially a plasma set which generates a lot of heat all by itself. If the fireplace is only used occasionally and you want to put the replacement set in the same spot, then I would consider a LCD model instead.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
