I require a set up code for a Telefunken TLED-26FHDP
0253,0250,0255,0241. Try these codes. If you wish to get more information, check these links. Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
SOURCE: Universal remote TVRC4N missing code
If you read your instruction booklet you will find a section for code unknown, or try thomson codes Ferguson have been made by Thomson for 15 years plus.
SOURCE: Remote control set up code
Try searching for the code
To search for your television code:
1. Switch your television on (not in standby).
2. Press and hold down MAGIC until the ONE FOR ALL
1 red light blinks twice (the red light will blink once
then twice).
3. Press 9 9 1. The red light will blink twice.
4. Next, press POWER.
5. Aim the ONE FOR ALL 1 at your Television. Now press
CH+ over and over, until your Television turns off
(every time you press the CH+ key the ONE FOR ALL 1
will send out a POWER signal from the next code
contained in the memory). You may have to press
this key many times (up to 150 times) so please
be patient.
If you skip past a code, you can go to the previous
code(s) by pressing the CH- key. Remember to keep
pointing the ONE FOR ALL 1 at your Television while
pressing this key.
6. As soon as your television
SOURCE: Sky TV Remote Control Code For Vistron 40" TV Required
please can you tell me code for vistron 32 hd from ebuyer got part of it working can not get sound to work , thanks
SOURCE: Need Universal Remote codes for Orion tv- One for All Remote
The TV codes for a URC-3021 and an Orion TV are:
0236, 0463
These are the steps to program your remote:
To setup your URC-3021 for a TV, these are the steps:
1. Turn on your TV.
2. On the remote control, press TV once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Enter the first four-digit code for your device. If performed correctly,
the LED will blink twice. If the LED did not blink twice, repeat steps 2 through 4 and enter the same code again.
5.
Aim the remote control at the device and press POWER once. The device
should turn off. If it does not, repeat steps 2 through 5, trying each
code until you find one that works.
