SOURCE: USER MANUAL
just go for google...
you can find english manual & drivers @ panasonic australia
http://panasonic.com.au/products/details.cfm?objectID=3696
scroll the page down to the end,
there you go
SOURCE: Need Driver for Panasonic nv-gs230 Camcorder Software to download
You should be able to just plug a USB into the camera connect it to your computer.
The camcorder should come up as an drive in "MY computer"
Try renaming any video that are named *.moi to *.mpg
if they wont play.
Hope this helps.
Sketchlab.com
Mugshot Collection
SOURCE: how can i change my panasonic nv-gs230 mini dv
Best
1. Copy the video to your computer with WinDV. No "capturing" involved. The video resolution and PAL/NTSC format will be the same as the source.
2. Then convert to whatever format you like.
You could also use something that copy and converts the video directly from the DV, like convert to dvd with Ulead DVD Workshop.
DV is a fixed standard and comes in 50Hz and 60Hz versions.
50Hz ("PAL" 625/50) 720x576, 25fps interlace (aka 576i)
4:2:0 components, 25Mb/s Video Rate
LPCM audio 2ch 16bit 48KHz or 4ch 12bit 32kHz
60Hz ("NTSC" 525/60) 720x480, 29.97fps interlace (aka 480i)
4:1:1 components, 25Mb/s Video Rate
Meaning, You cannot change the camera. It is either a pal camera or a ntsc camera. Othewise you will have to by a firmware update from the manufacture's website.
SOURCE: my new computer has windows 7, i cant find any
try using windows XP mode to run an older program (you can download windows xp mode from microsoft.com)
