SOURCE: How to Network the scan function of a Gestetner DSm635
Most IT departments don't know how. They won't admit that but it is true. You already print to the thing so all that has to happen is setting up SMB shares on the computers and telling the scanner where to scan. Your very best option would be to contact your printer repair company and ask if they have a connectivity or networking specialist that could help you. If they are a good company they may even call your IT people and help them help you. And of course nothing technical comes for free.
I hope that helps.
SOURCE: how to scan a doc on Gestetner Copier
You can install the Twain scanning driver which is provided on the Printer driver CD. Insert this CD and select to install the Twain driver only.
After installation od this driver, please open Word document and click on Insert, Picture and select from Scanner or Camera. Check and choose your twain scanner driver and click on insert.
Beforehand you must put the original on the exposure glass.
Try this or you can use scan to email but you need more setup details.
Hope you good luck.
SOURCE: GESTETNER DSM627 COPIER, SCANNER, FAX
The basic scanning method is to use the Twain driver, found in the printer driver disc.
Install it on your computer.
Put original on the exposure glass.
Open Word document, click insert, select from scanner or camera
and select your device scanner and click on insert.
Then you can save it and attach it to an email.
Hope I was helpful, please rate me, thanks.
