Are you meaning the
Water Inlet Solenoid Valve??????
If yes .... you need to know if your W/P Duet GHW9150P Front Load Washer really has a bad
Water Inlet Solenoid Valve for the Hot and Cold water. This valve is where the Hot and Cold water hoses connect to the rear of your washer on the upper top left side in the rear as you are facing the washer.
In my opinion it is highly unlikely that your Water Inlet Solenoid Valve is bad....but it is possible. Sometimes the filter screen in the inlet(s) of the Hot & Cold water valve can be stopped up with dirt, sediments, etc. If you turn off the water faucets and remove the Hot & Cold water hoses from the washing machine... you will be able to see the screens...if they are stopped up you can remove them with a small screw driver and clean them and reinstall them.
Hook up your hoses and turn on your water supply Hot and Cold faucets. Here is a quick test procedure that you can do to verify the operation of the
Water Inlet Solenoid Valve. Verify that your water hoses are hooked up and the water faucets (Hot & Cold) are turned on.
Unplug the washer's 120Volt AC power supply cord from the electrical plug on the wall. (1) Remove the top cover...There will be three screws on rear area of the cover: Left - Middle -Right.
(2) Once the top cover is removed...you will be able to see the
Water Inlet Solenoid Valve...just follow the Hot & Cold water hoses from the wall to your washer. Usually the water inlet solenoid has a blue plastic housing assembly with (2) separate
push-on or
pull-off quick disconnect electrical connectors. One connector pair provides 120volt AC to the Hot water solenoid and the other connector pair provides the 120volt AC to the Cold water solenoid.
(3) Remove the
push on or
pull off quick disconnect electrical connector to
one of the water inlet solenoids..It does not matter which one at this point in time.
(4) You will need an electrical
120v AC Test Cord. You can make this from an old lamp AC power cord or and old 120v AC Extension Cord. You will need two alligator test jumpers or leads (Radio Shack has them). The end of the test cord that plugs into wall is not to be modified. The other end of the test cord will have to be modified in order to conduct this testing. Strip back the insulation to reveal the two leads that will carry the 120v AC power. You should have one black lead (120v AC HOT) and one white lead (120v AC Neutral). Connect (1) alligator test lead to the black lead and insulate with electrical tape as necessary and connect (1) alligator test lead to the white lead and insulate with electrical tape as necessary You now have your
120v AC Test Cord ready. If you have a VOM test meter..you can connect the VOM meter to the two remaining alligator test leads. Have your VOM test meter set for AC Volts and on a scale that will measure 120v AC. Plug in your test cord to the 120V AC wall power. If everything is OK your meter should read approximately 120 Volts AC.
(5)
Unplug your 120v AC Test Cord from the wall power.
(6) Connect your
120v AC Test Cord to your
Water Inlet Solenoid Valve electrical terminals.
See Step (3).(7) Plug your
120v AC Test Cord into wall power.
If the water solenoid valve is good you should hear water surging thru the water solenoid valve. If you do not hear the water running thru the valve you can verify if the 120v AC is getting to the valve with your VOM. It should read 120v AC. If it does read 120Volts AC at the terminals of the valve and you do not hear the water then the valve is probably defective: Either stuck shut and won't open or the solenoid coil is open (Bad).
(8) Unplug your
120v AC Test Cord from wall power.
(9) Disconnect your (2) alligator test leads from the solenoid valve and re-install the electrical
push on connectors that was disconnected in Step (3)
(10) You can now repeat this test on the other side of the
Water Solenoid Valve (See Step 3).
(11) If both sides of the Water Solenoid Valve check out good...then your
Water Inlet Solenoid Valve is good. If it does not check out then replace it.
(12) If your
Water Inlet Solenoid Valve is good...then ....unfortunately, there is a good chance that the CCU module is bad. The CCU module is in effect a computer control unit and controls the overall operation of the washer. The CCU module will cost approximately $150.00
If you need further help, I’m available over the phone at
https://www.6ya.com/expert/henry_239f63a136de60f0
