I need to find a copy of the primary data for a Magellan Mastro 3225 GPS. Magellan says that that cannot provide the data so I have to spend $75 to have the GPS replaced, which is ridiculous. Does any one know where I can get a copy of the default data for this GPS.
Thanks in advance.
J. Victor Morrill
SOURCE: Magellan 3225 - frozen on start up page
contact magellan corp custmomer service or repair tech,they can help call them first
SOURCE: magellan maestro 3225 (user guide manual)
Hi
You can get the user's manual from link below
http://www.magellangps.com/assets/manuals/maestro_3225_manual_en.pdf
SOURCE: Need to update the maps
I need to update the map on my 3225 Magellan Maestro, can anyone help?
SOURCE: My Magellan maestro 3225 wont charge or start up
Same here - the problem, at least with mine, is that the power pin on the unit has become loose and not making contact with the machine - thus will not charge most likely from pluging and unplugging it in multiple times and breaking the connection inside the unit - FWIW, this GPS a real piece of **** and I have already replaced it with a Garmin- I'm trying to figure out how to take it apart to see if I can solder the power pin back in place but it is not as easy as removing the 4 back screws...
