No lights no power
I have had the same problem. Can be of two things.
1) Issue with the charging circuit. When you plug your charger on it should indicate a yellow light. If not, either your charger is not working or your charging circuit is not working. Go to the store and get them checked.
2) Issue with the battery contacts. Simply take out the battery and get a cotton bud and clean the battery contact both on the battery and inside the battery compartment.
3)Issue with the charging circuit and the internal circuitry. You will have to take it to the KoDAK store. I would recommend buying a new one.
