Coleman Powermate Powermate 5000W Generator Logo
r
robvann Posted on Dec 22, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Coleman Powermate full throttle
Governor doesn't seem to be working. It runs at full throttle unless I manually force the throttle back.
  • robvann
    robvann Dec 22, 2013
    The owners manual DOESN'T seem to include information about the Tecumseh engine, which is where the mechanical governor is located.
stargajzer
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 79 Answers
  • Posted on Dec 22, 2013
stargajzer
Expert
Level 2:
Cheetah:
Answers
79
Questions
0
Helped
24317
Points
144
There may be a choke handle that should reduce the engine RPM. Otherwise contact the Coleman technical support department.
4 Related Answers
HANK MCNEIL
  • 252 Answers
  • Posted on Mar 11, 2009
SOURCE: need manual for my Coleman Powermate generator
Get model number and go to: http://www.powermate.com/productmanuals.php?cat_id=3
Anonymous
  • 13 Answers
  • Posted on Sep 27, 2008
SOURCE: Powermate PM0535000-01 Manual
powermate went out of business , but this might help let me know http://www.powermate.com/contact.php
Anonymous
  • 174 Answers
  • Posted on Jun 08, 2009
SOURCE: How can I get a owners/instruction Manual for my
follow this link to get the user manual guide as per your model no:
http://arkansas-ope.com/COLEMAN_GENERATORS.html
Anonymous
  • 3 Answers
  • Posted on Oct 13, 2009
SOURCE: Does anyone know where I can download an owners
Try this link. The model number will be on your generator.
Need adjustment procedure and breakdown of governor.
check that you have the governor control rod on the butterfly lever of the carby connected correctly
it appears that the lever is at full throttle when you connected it and so the governor cannot pull it back to correct speed
if correct the throttle will be at full speed when stopped but will move with the go lever to slow when you manually push the gov lever
My coleman powermate runs fine under load, but rpm fluctuates with no load. Any ideas?
Its is a governor or fuel issue. Start with the fuel make sure all and carb is set correectly and tune dup. Then check the governor. Make sure also you have correct weight and viscosity oil and level
My coleman started running at a super high rpm. I know it's the governor, but how do I adjust?
It sounds like the governor arms internally are broken, can you feel any resistnce? if not then it will need a tear down to fix
I HAVE A POWERMATE 5000 THAT SHUTS DOWN UNDER LARGE LOAD . I THINK I NEED AN IDLE CONTROL MODULE.THERE IS A 2 WIRE MODULE IN THE START CKT. #21009XA IS THIS IT AND WHERE DO I GET ONE .
Idle control comes into play when there is no power draw forcing the engine to idle with an electro magent. If you feel that the electro magnet is interfering with governor, temp remove the wire to the solenoid. Usually the idle control will not effect how the engine /gen output power. An overloaded condition will cause the engine the go the full throttle as the internal governor of the engine will try to maintain 3600 rpm. Overloaded condition will greatly shorten the life of the generator/engine. Try to use only about 80 % of rated power. Large motors can draw three times running amps. A compressor using 12 to 18 amps to run can draw over 40 amps to start.
If your generator could handle the load in the past, check the engine for loss of power, or the generator for faulty voltage regulator or capacitors out of range. Easy to check. Connect digital volt meter to plug /load and look at volt reading while running with no load and loaded. Voltage should stay between 110 to 120 under load and with no load (unless goes into idle mode). Good luck
1helpful
I have a briggs & stratton / Powermate portable generator; there is a lever with a black plastic handle on the end of it, right next to the 'choke - run' lever which has a red plastic tip on it. ...
The engine on your generator is also used for other applications some of which require an adjustable  throttle control. On a generator the engine must turn about 3600 rpm to obtain proper output of voltage and cycles. Upon further inspection of your throttle/governor you will probably find an adjustment consisting of a screw, nut or a tab on one end of the governor spring that can be reset for proper engine speed. (tab can be bent for more or less tension on spring) To check present governor setting, use a volt meter that has frequency setting. Make sure that generator is set to about 60 hz. (3600rpm) Good luck with your generator.
I have a porter cable 5250 generator that bounces off the governo
there 2 linkages that conect that would be the problem. you have on conected to the throttle switch that runs to the govener than on that govener os another linkage hooks up to it and runs to the carborator that ajusts the flow. if you don't have both linkages than you need to order 1.
1helpful
2answers
Surging 5000w Coleman Generator
I had a Colman that only surged when it had a large load on it. ConsumerReports.org says that some Coleman generators just can't hold a constant voltage. Hondas are expensive but very good,.
2answers
Generator will not produce electric power
Check the air cleaner to make sure that it isn't clogged with oil. If you find any significant amount of oil you may also need to clean the carb. Also check the spark plugs for fouling. Once you're convinced that the engine has no service related issues, check the governed throttle setting. To do this find the spring that pulls on the governor arm and look for either a tab to bend up or a threaded rod to tighten at the end of the spring not connected to the governor arm.
Regards,
Carl
6helpful
2answers
ENGINE OVER SPEEDS WHILE RUNNING
This is almost surely a problem with the governor, check it like this.
Have someone with a finger on the kill switch.
Watch the governor arm while starting the engine, if it does not move almost immediately after starting the engine it is broken.
This is not a simple repair as it involves taking the crankcase apart, you'll have to contact robin/subaru to get a parts list in order to get the right governor spool and weights.
For an experienced technician this is about a 2 hour repair task.
Hope this helped,
Carl
Top Coleman Electrical Supplies Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
john h
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
