Set the washer to normal to run, it ran fo 10 minutes, then started to spin and then stopped with error LE flashing. I unplugged the power for 30 minutes and did exactly what was suggested on the HELP but still didn't work. Do I need to call for service and how much would it cost?
SOURCE: When to know if the motor is going out ?
This fix below completely fixed my LG front loader issue of the drum "freezing" and "studdering" on fill and a lot of times giving a LE (motor overload) error. Bought position sensor as described and doing a load right now!
Wolfster you are awesome...you saved me probably $200.
Definitely sounds like the position sensor is faulty. I had this happen
to my WM2277HB recently. Motor would start to turn, then jerk, hum, and
not move, eventually gives LE code. Powering down, all the other tips
had no effect. Very unlikely that the motor itself is bad if it still
turns freely. You could confirm the stator wiring is OK by unplugging
it and taking resistance readings across the stator terminals of the
3-pin connector (any combo of two should be 7-15 ohms). I was able to
order the part from an online electronics supplier (www.mcminone.com,
P/N 6501KW2002A, description is "sensor assembly") and several other
places may have it as well. You can download a basic but somewhat
helpful service manual here http://136.166.4.200/contents/Laundry/WM2277.htm
that has some disassembly instructions and exploded view diagrams,
explains the troubleshooting mode. Don't even bother calling LG or a
service tech unless it's under warranty. If you're here you probably
have some basic repair skills and tools
and can easily replace it yourself for about $20. My washer was about a
year and a half old when the sensor went out, now it runs great again.
SOURCE: LG WM1812CW PROBLEM
Just had this same problem on my LG wm1832CW machine. Sensor assembly was replaced and all is well..
Simple and fairly inexpensive to replace.
SOURCE: LG WM2077CW LE Error, won't spin
It sounds like the motor sensor has failed and needs to be replaced. Yes a DYI can do it. The sensor is in the back.
Remove the back cover.
Use a 17mm socket to remove the center bolt holding the rotor. Remove the rotor by pulling it straight out. It will be hard but keep pulling.
Now use a 10mm socket to remove the 6 bolts holding the stator assembly. Carefully remove the stator and turn it around to locate two connectors. The 5 wire connector is the motor sensor. Replace it and reinstall and it should work fine.
SOURCE: LE ERROR CODE ON LG WM-2277HW
Don't call service, they will rip you off!
See posted titled "LG Tromm WM2277HW will not spin"
SOURCE: "le" on the LG WM0532hw front load washer errror
try unpluging for 45 seconds than hold in the selector knob for 10 sec. & plug back in
