Please remove battery and place the + and - side according to the battery-located instructions or symbols provided. If the tablet does not work after that, please use a different pair of batteries to attempt to turn on the tablet.
If it's a newer tablet it should be rechargeable. And a red battery light indicates the need for it to be charged. On one of the side edges of the tablet there should be a micro USB or other port for a charging chord to plug into.
Can you open up the back where the battery is located? check the contacts for cleanliness and replace the battery .Sometimes all you need to do is open the case, replace the battery and the tablet will start.
The battery on the zeepad 7.0 is located inside,first turn off unit then take a fine blade insert the blade ever so gently between the edge you'll see the seam with the blade inserted pry downward along the edge you'll hear it pop open as you pry down.
You can follow the user manual guide of your tablet and locate the ip address in your tablet.Then visit the site Ip-details.com here it display ISP, IP location,Country and so on...
You'll have to open up the laptop and get free access to the motherboard. Usually CMOS batteries on laptops are soldered onto the motherboard so you'll need to have some soldering skills to do this. About the price, usually it's in the $10 range, but the best way to go is to get the original battery and visit the local wrist watch store or a specialized batteries store and ask for a replacement.
If this was helpful and informative please vote with a Thumb Up. Thank you.
