SOURCE: Bosch Washer WFK 2401
leaks could be from anywhere. remove the top and back cover, put on a cycle and try to trace where leak is. sorry if this is not very helpful. water in filter should not smell. this may be due to using liquid detergent which causes a smell like drains if used over a period. put on a boil wash and revert to using powder
SOURCE: Bosch nexxt washer is leaking from underneath
I found out why mine leaks. In the Bosh design there is a trap molded into the soap dispenser plastic tray. This tray or trap has a wide open path to the inside of the washing machine. We are using the tide pods as a detergent. Two things are going on here. This trap fills up with water immediately when water is cycled into the machine. The second thing is the pods partially dissolve and leave a gunk that blocks the water pathway to the drum. This blockage eventually allows water to pass however when the pressure is high and this blockage is restricting the water level rises and the trap dumps out into the washer panels. This water immediately leaks down and out the bottom. Observation when I disassembled the machine the trap was moldy and stinky. Water stains were running down the inside. Maybe the engineers at Bosch should look into this.
