Won,t light
SOURCE: 2000 nissan maxima won't fire
sounds like it might be flooded. Try and remove the fuel pump fuse from the fuse block that is just in front of your left knee. While it is out crank the car and see if it wants to start and hold down the gas pedal all the way and then relase it and back and forth and once you get it to run have the fuse ready in your hand and in front of the spot to install it. and then keep the rpm's up with the gas pedal until the smoke clears out behind the car.
