SOURCE: memory card
Did you just buy this card or have you had it working for a while and now this is happening?
From everything i have read about your camera, they won't take a 2 Gig card. A 1 GIG card is the biggest that is compatible with this camera. If the card is new i would take it back to the store and see if they will let you exchange it for a 1 GIG card.
If this just started happening after using it for a while -- it could be a problem with the card or the camera. Try putting in a different card and see if it will let you format that one. If it does you know for sure the problem is with the card. If you keep getting the same message no matter what card you use, i would phone Kodak. But, according to Kodaks own site, 1 GIG is the biggest card that is compatible. Sorry I couldn't be more help.
Good Luck.
SOURCE: new memory card says memory card full
The following memory cards are compatible with your Kodak EasyShare C330 Every memory card we offer is manufactured to the highest standard and carries a 2 year minimum warranty.Your Kodak EasyShare C330 accepts SD Card cards.The largest SD Card card you can use in your Kodak EasyShare C330 is 1GB
SOURCE: why is the camera stating memory card is full?
Hello, I have the same camera, I went to buy a Kodak memory card and the Representative was kind enough to ask me what digital camera, he said that the c330 will only take a 1GB SD Memory Card. Hope that helps.
SOURCE: kodak easyshare cw330 new memory card reads full....
Camera doesn't support more than 1GB memory card, so better use less than 1gb SD card
..........Prashant
SOURCE: 2GB SD card is brand new but camera says it is full.
Some of the older cameras will not take the bigger cards. You can use the bigger card with your computer to store your photos.
